Date Time Control in field values not formatting date as per desired format
We have an issue where audit does not show datetime values as part of the history memo, in a desired format.
Field values arebeing used to transform audit messages at run time. Field values are being passed datetime values as parameters too. Datetime values are in Pega format, but we want to show as "yyyy-MM-dd" at run time.
Applying OOTB control in field values are not working and if we create our own control to write our own java code, Pega gives a severity warning on newly created control.
Does anyone has any OOTB solution for this?
