Invalid Expression when adding Boolean Expression in Pega Robot Studio
When adding a boolean expression to an Automation, e.g. a==b. If you go to the properties and try to change the data type for the two variables from Double (default) to String, you get an error "InvalidExpression" in the Design Area. I've tried to Clean Solution and Rebuild with no luck. (see attachment: invalid_expression.png)
What I found works is to select "Identifiers - String" by right click in the Boolean Expression in the local variables of the automation. (see attachment: identifiers_string.png)
Probably not a fancy workaround but it took me a while to figure it out how to continue the automation by doing this. It might save some time for anyone experiencing this issue.
Cheers :)
