How to customize account disabled error message when logging in with SSO?
When using a SAML2 authentication service, if a user attempts to access the system but their operator id is marked as disabled, they get an error message "Your account has been disabled, contact your administrator"
I need to be able to customize this message.
I cannot find an appropriate rule in the system that contains this message for our scenario so am assuming it is set in the API engine itself. However, I'm assuming it can be intercepted and amended!
I've set additional logging on the following but nothing shows up, so I'm probably looking at the wrong activities etc
com.pega.pegarules.integration.engine.internal.util.PRSAMLv2Utils com.pega.pegarules.integration.engine.internal.sso.saml.SAMLResponseHandler com.pega.pegarules.integration.engine.internal.sso.saml.SAMLRequestHandler com.pega.pegarules.integration.engine.internal.sso.AbstractSSOHandler com.pega.pegarules.integration.engine.internal.sso.saml.SAMLv2ACSHandler
Can anyone please help?
***Edited by Moderator: Pallavi to change content type from Discussion to Question***
