S & P Global Company Ltd
Posted: May 17, 2020
Last activity: Aug 4, 2020
Last activity: 4 Aug 2020 15:34 EDT
Getting issue while ingratiating with Jenkins
Started by user abinash Running as SYSTEM [EnvInject] - Loading node environment variables. [EnvInject] - Preparing an environment for the build. [EnvInject] - Keeping Jenkins system variables. [EnvInject] - Keeping Jenkins build variables. [EnvInject] - Injecting as environment variables the properties content SystemName=$BUILD_TAG SourcePassword=rules SourceHost=http://localhost:5080 SourceUser=abinash [EnvInject] - Variables injected successfully. [EnvInject] - Injecting contributions. Building in workspace C:\PRPC8.4\CICD\workspace\JenkinPega [EnvInject] - Unset unresolved 'USERNAME' variable. [EnvInject] - Executing scripts and injecting environment variables after the SCM step. [EnvInject] - Injecting as environment variables the properties content ImportExistingInstance=skip ARTIFACTS_DIR=C:\PRPC8.4\CICD [EnvInject] - Variables injected successfully. [jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -Dtargethost=http://localhost:5080 -Dtargetpassword=rules -Dapplicationversion=01-01-01 -Dproductname=Jenkins -Dproductversion=01.01.01 -Dtargetuser=abinash -Dapplicationname=Rectile exportprops && exit %%ERRORLEVEL%%" Buildfile: C:\PRPC8.4\prpcServiceUtils\scripts\samples\jenkins\Jenkins-build.xml exportprops: [propertyfile] Creating new property file: C:\PRPC8.4\CICD\workspace\JenkinPega\jenkins-JenkinPega-7_export.properties BUILD SUCCESSFUL Total time: 0
Show More
Started by user abinash Running as SYSTEM [EnvInject] - Loading node environment variables. [EnvInject] - Preparing an environment for the build. [EnvInject] - Keeping Jenkins system variables. [EnvInject] - Keeping Jenkins build variables. [EnvInject] - Injecting as environment variables the properties content SystemName=$BUILD_TAG SourcePassword=rules SourceHost=http://localhost:5080 SourceUser=abinash [EnvInject] - Variables injected successfully. [EnvInject] - Injecting contributions. Building in workspace C:\PRPC8.4\CICD\workspace\JenkinPega [EnvInject] - Unset unresolved 'USERNAME' variable. [EnvInject] - Executing scripts and injecting environment variables after the SCM step. [EnvInject] - Injecting as environment variables the properties content ImportExistingInstance=skip ARTIFACTS_DIR=C:\PRPC8.4\CICD [EnvInject] - Variables injected successfully. [jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -Dtargethost=http://localhost:5080 -Dtargetpassword=rules -Dapplicationversion=01-01-01 -Dproductname=Jenkins -Dproductversion=01.01.01 -Dtargetuser=abinash -Dapplicationname=Rectile exportprops && exit %%ERRORLEVEL%%" Buildfile: C:\PRPC8.4\prpcServiceUtils\scripts\samples\jenkins\Jenkins-build.xml exportprops: [propertyfile] Creating new property file: C:\PRPC8.4\CICD\workspace\JenkinPega\jenkins-JenkinPega-7_export.properties BUILD SUCCESSFUL Total time: 0 seconds [JenkinPega] $ cmd /c call C:\WINDOWS\TEMP\jenkins8496441852522501356.bat C:\PRPC8.4\CICD\workspace\JenkinPega>C:\PRPC8.4\prpcServiceUtils\scripts\utils\prpcServiceUtils.bat export --connPropFile C:\PRPC8.4\CICD\workspace\JenkinPega>Started by user Abinash lenka 'Started' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>Running as SYSTEM 'Running' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Loading node environment variables. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Preparing an environment for the build. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Keeping Jenkins system variables. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Keeping Jenkins build variables. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Injecting as environment variables the properties content '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>SystemName=$BUILD_TAG 'SystemName' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>SourcePassword=rules 'SourcePassword' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>SourceHost=http://localhost:5080 'SourceHost' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>SourceUser=abinash 'SourceUser' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Variables injected successfully. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Injecting contributions. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>Building in workspace C:\Program Files (x86)\Jenkins\workspace\JenkinPega 'Building' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Unset unresolved 'USERNAME' variable. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Executing scripts and injecting environment variables after the SCM step. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Injecting as environment variables the properties content '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>ImportExistingInstance=skip 'ImportExistingInstance' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>ARTIFACTS_DIR=C:\Program Files (x86)\Jenkins 'ARTIFACTS_DIR' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[EnvInject] - Variables injected successfully. '[EnvInject]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -DProductName=Jenkins -DTargetHost=http://localhost:5080 -Dapplicationversion=01.01.01 -DTargetPassword=rules -DProductVersion=01.01.01 -DTargetuser=abinash -Dapplicationname=jenkins exportprops && exit %ERRORLEVEL%" '[jenkins]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>Buildfile: C:\PRPC 8.4\prpcServiceUtils\scripts\samples\jenkins\Jenkins-build.xml 'Buildfile:' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>exportprops: 'exportprops:' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[propertyfile] Creating new property file: C:\Program Files (x86)\Jenkins\workspace\JenkinPega\jenkins-JenkinPega-22_export.properties '[propertyfile]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>BUILD SUCCESSFUL 'BUILD' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>Total time: 0 seconds 'Total' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>[JenkinPega] $ cmd /c call C:\WINDOWS\TEMP\jenkins1365811151645664034.bat '[JenkinPega]' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>C:\Program Files (x86)\Jenkins\workspace\JenkinPega 8.4\prpcServiceUtils\scripts\utils\prpcServiceUtils.bat export --connPropFile 1>C:\PRPC 'C:\Program' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>'C:\PRPC' is not recognized as an internal or external command, The filename, directory name, or volume label syntax is incorrect. C:\PRPC8.4\CICD\workspace\JenkinPega>operable program or batch file. 'operable' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>C:\Program Files (x86)\Jenkins\workspace\JenkinPega Files (x86)\Jenkins\workspace\JenkinPega\jenkins-JenkinPega-22_export.properties --artifactsDir C:\Program Files (x86)\Jenkins\workspace\JenkinPega 1>C:\Program 'C:\Program' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>'C:\Program' is not recognized as an internal or external command, The filename, directory name, or volume label syntax is incorrect. C:\PRPC8.4\CICD\workspace\JenkinPega>operable program or batch file. 'operable' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>C:\Program Files (x86)\Jenkins\workspace\JenkinPega 9009 1>exit 'C:\Program' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>Build step 'Execute Windows batch command' marked build as failure 'Build' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>Sending e-mails to: [email protected] 'Sending' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>ERROR: Could not connect to SMTP host: localhost, port: 25 'ERROR:' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>javax.mail.MessagingException: Could not connect to SMTP host: localhost, port: 25; 'javax.mail.MessagingException:' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>nested exception is: 'nested' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>java.net.ConnectException: Connection refused: connect 'java.net.ConnectException:' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1934) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:638) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at javax.mail.Service.connect(Service.java:295) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at javax.mail.Service.connect(Service.java:176) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at javax.mail.Service.connect(Service.java:125) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at javax.mail.Transport.send0(Transport.java:194) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at javax.mail.Transport.send(Transport.java:124) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.tasks.MailSender.run(MailSender.java:130) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.tasks.Mailer.perform(Mailer.java:176) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.tasks.Mailer.perform(Mailer.java:139) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:741) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:690) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.Build$BuildExecution.post2(Build.java:186) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:635) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.Run.execute(Run.java:1881) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.ResourceController.execute(ResourceController.java:97) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at hudson.model.Executor.run(Executor.java:428) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>Caused by: java.net.ConnectException: Connection refused: connect 'Caused' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.AbstractPlainSocketImpl.connect(Unknown Source) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.PlainSocketImpl.connect(Unknown Source) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.SocksSocketImpl.connect(Unknown Source) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at java.net.Socket.connect(Unknown Source) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at com.sun.mail.util.SocketFetcher.createSocket(SocketFetcher.java:286) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:231) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1900) The AT command has been deprecated. Please use schtasks.exe instead. Invalid command. The AT command schedules commands and programs to run on a computer at a specified time and date. The Schedule service must be running to use the AT command. AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]] AT [\\computername] time [/INTERACTIVE] [ /EVERY:date[,...] | /NEXT:date[,...]] "command" \\computername Specifies a remote computer. Commands are scheduled on the local computer if this parameter is omitted. id Is an identification number assigned to a scheduled command. /delete Cancels a scheduled command. If id is omitted, all the scheduled commands on the computer are canceled. /yes Used with cancel all jobs command when no further confirmation is desired. time Specifies the time when command is to run. /interactive Allows the job to interact with the desktop of the user who is logged on at the time the job runs. /every:date[,...] Runs the command on each specified day(s) of the week or month. If date is omitted, the current day of the month is assumed. /next:date[,...] Runs the specified command on the next occurrence of the day (for example, next Thursday). If date is omitted, the current day of the month is assumed. "command" Is the Windows NT command, or batch program to be run. C:\PRPC8.4\CICD\workspace\JenkinPega>... 18 more '...' is not recognized as an internal or external command, operable program or batch file. C:\PRPC8.4\CICD\workspace\JenkinPega>Finished: FAILURE 'Finished:' is not recognized as an internal or external command, operable program or batch file. Build step 'Execute Windows batch command' marked build as failure Finished: FAILURE
Show Less
