How to modify the application Name while triggering from agent
I have a requirement like
On approve - parent case is routing to a workbasket ,from workbasket Agent will pick and create a child case.
Issue:
When child case creation application name by default set as "pegarules"
In my application we are fetching records based on application name where it is a framework layer 2 applications using same workbasket
Can we change application Name when it is triggering from agent?
Do you want to change the pxApplication property in the pyWorkPage?
If yes, you can do a property-set post child case creation with the correct Application name.
