Create Releasepipeline for Componente with Deployment Manager
Hi Everyone,
i would like to create a Releasepipeline for a componente woth Deployment Manager.
Have anyone experience with Componente Releasepipeline? How could the test coverage for a componente be caculated in pipeline.
I did following steps to define the pipeline to deploy a Component A
1. create a component A_QA, which takes A as prerequiste.
2. save test cases in the Component A_QA ruleset, define Accessgroup for Component A_QA.
3. enable the checkbox "deploy test cases" in Deploymentmanager
4. start deployment
5. process failed on validate test coverage, although it has 70% test coverage, it throwed an error that the test coverage only 0%.
Then i tried to save A_QA rulest direct in Component A, it throwed the same error.
i am appreciated for any answer.
