Healthfirst
Last activity: 17 Apr 2020 11:32 EDT
Pega 7.2.2 Key Store Generation (Needed for SFTP server configuration) using .PPK file
1. Unable to load PPK file in Key Store Configuration needed for SFTP server Configuration("DATA-ADMIN-CONNECT-FTPSERVER" instance)
2. Only allowed values for keystore type is (JKS, PKCS12, KEY, KEYTAB)
3. Receiving below error when I try to enter keystore type as PPK and save (Invalid value for Keystore type. Specify one of [JKS, PKCS12, KEY, KEYTAB] )
4. Found below article for 7.2.1 Keystore generation using PPK file
Followed the steps and commented step 3 in "activitiy Data-Admin-Security-Keystore.Validate" but still throws the same error as above ( step 5 Java code is explicitly checking for file types, JKS, PKCS12, KEY, KEYTAB )
Please advise for further steps.
***Edited by Moderator: Pallavi to change content type from Discussion to Question***
