WellsFargo
Last activity: 15 Apr 2020 11:48 EDT
Query on Pega API - Refresh action details of the assignment
I have a question on ' Refresh action details of the assignment API'. Below is the list
1) What is the use of refresh for parameter and how can I use it?
2)
USE CASE: I have screen with 2 fields Proeprty1 and Property2. Property2 should be visible when Property1 is not empty and Property1 has an on change event to refresh the section and call either a data transform or activity , in activity or data transform I am setting the property2 with some value and logging a message.
I am calling the /assignments/{ID}/actions/{actionID}/refresh API passing the request body as {"content": { "TestProperty":"value111" }} , I am getting the response with Property2 in JSON response but the value which was set in the refresh section activity of Proeprty1 is not set.
QUESTION:
A) Does refresh section and corresponding activity or data transform gets called when calling this API?
B) How can I use the 'refresh for' parameter for this use case?
C) Is there any documentation on in depth details on how to use these API's?
Suman
