Accenture
unable to see change tracking tab pega in declare expression
I am unable to see change tracking tab in declare expression rule.
Please find the attached screenshot.
Please can anyone tell why its not visible. I have administrator access.
Thanks & Regards,
Priya Dubey
Updated: 14 Jun 2021 7:38 EDT
As per Pega's latest version, the Change Tracking tab has been removed, if you want to have change tracking tab, go to the Action menu and select "Use legacy expression".
Please find below article which might be helpful.
Accenture
attached screenshot
Priya Dubey Sathya Venkatraman POOJA KUMARI M B Pruthvi Raj Dara POORNIMA P P
Accenture
Also to add, when I create a declare expression it directly asks me to select the Target Property and doesnt give option to enter label for the rule. Please find the attached screenshot.
If you want to change the label of the declare expression rule, you can change in the rule form. But as a best practice, we need to use the property name as a label.
Please find the below screenshot for more details.
Priya Dubey POOJA KUMARI M B
Accenture
attached screenshot
In simplified declare expressions the target property's value is only calculated whenever used. Additionally, expressions are always executed regardless of the context of the pages they are contained in. Ref:https://community.pega.com/sites/default/files/help_v83/procomhelpmain.htm#rule-/rule-declare-/rule-declare-expressions/supported-and-unsupported-configurations-i
