Comdata Spa
IT
Last activity: 9 Mar 2020 7:57 EDT
We are facing some issues developping your test application : CTXCalcNOTEPAD into our Citrix Server.
Pega Version : Pega RPA 8.0.2019.0
Citrix version : Xenapp 6.5
We need to develop a robot running a customer CRM in the Citrix server. The Robot must be run in parallel on many clients that have credentials allowed to log in the Citrix environment.
Using a Citrix Desktop and a PEGA Studio we have been able to easily develop the Robot itself.
Basically the automation needs two input string parameters used throgh the automation and require an output parameter to describe the result.
We have found in your web your document and followed the istruction to obtain a mixed Robot partially running on the Server and a program on the Client side.
We have created your project : CTXCalcNOTEPAD here enclosed as zipped file.
Has suggested in the enclosed ‘Using Citrix Context ‘ document, we have tried to use the option : ‘Run Local = True’.
We have not published any thing but just run in ‘Local mode’ the test Project. The error detected is here enclosed. In order to let you know, we have a Develop machine but we are not sure about the set up of the ICA Client has been done properly.
IE : we have the directory \ICA Client under Program Files (x86) but NO dll as you point out in the document
pag: 5 in the same directory as wfica32.exe.
We send you the bitmap with the error, and our test project. We need to have proper istruction today available for our Pega version/Citrix version and all direction to follow in order to fullfill our requirements.
***Edited by Moderator Marissa to update Content Type from Discussion to Question; update Type from General to Product; update Product**
