PDF Stream open in Pop Up
Below is my requirement:
1. On click of a link , i will pass some parameter to rest service.
2. Rest will return PDF in 64 bit encoded format stream (background)
3. On click of link need to open a new window to show this PDF stream decoded. (should not attach PDF to Work object) . Just PDF viewer and we can save the PDF if necessary in local.
How to achieve this? Any OOTB rules available ?
Need solution for this urgently. Thanks in advance.
