Regarding property pyaccessgroups_opid.
Need to understand the significance and use of the property pyaccessgroup_opid.
I believe this is a needed property to create AccessGroups within an activity.
For add Access Group to an operator, you need to add both pyAccessGroupAdttional and pyAccessGroup_opid PageList.
Creating an activity to add an Activty to an Operator's pyAccessGroupAddtional property. On clipboard, you will need pyAccessGroupAddtional with a proper value and pyaccessgroup_opid should be handling operator id.
I think.
Hi Samiulla,
pyAccessGroup_opid is the PageList Property that holds the List of AccessGroups available to the specific Operator, when we open any operator instance.
WhereAs, pyAccessGroupsAdditional is a valueList property that has all additional AccessGroups that specific Operator can switch.
Satish Mogilicherla.
whenever we are creating an operator is it mandatory to add pyAccessGroup_opid property?, if we have pyAccessGroupsAdditional to hold the access groups, wanted to know is there any specific reason to use pyAccessGroup_opid . Please advice.
