Service REST rules and Custom/Kerberos Authentication
Hi Pega Community,
I am trying to setup Kerberos authentication for my REST Service rules.
I already have a working Kerberos Authentication Service Rule + properly configured Tomcat/SPNEGO SourceForge/Web.xml for Web/Portal SSO login.
For the REST Services I did a "Save As" for my existing Authentication Service and created a new one of type "Custom" running the same activity, and configured my Service Package to "Custom" authentication and chose my new Authentication Service - "ServiceKerberos".
However I think I might be missing in my web.xml configuration. I configured a new servlet called "ServiceKerberos1" which is basically copied from the my working (delivered) WebKerberos1 servlet. What I did change/add was these params (taken from the "WebRestService" servlet):
Hi Pega Community,
<init-param>
<param-name>PegaEtierClass</param-name>
<!--param-value>com.pega.pegarules.services.http.HTTPService</param-value-->
<param-value>com.pega.pegarules.integration.engine.internal.services.http.HTTPService</param-value>
</init-param>
<init-param>
<param-name>CharacterEncoding</param-name>
<param-value>UTF-8</param-value>
</init-param>
<!-- Indicate that R-S-REST never handles static content-->
<init-param>
<param-name>HasStaticContent</param-name>
<param-value>false</param-value>
</init-param>
I also obviously added a new Servlet Mapping for my Servlet like so: "/PRServiceKerberos1/*"
My problem is this:
I am trying to invoke my REST service through this URL:
https://mypehahost.com/prweb/PRServiceKerberos1/mypackage/v1/myservice
I am prompted for a User/Pass and after successfully logging in I get an HTTP 500 with this exception in the log:
Caused by: com.pega.pegarules.pub.PRException: Failed to retrieve Rule-Service-HTTP instance myPackage.v1.myService using service package access group APP:APPAdmin
I am sure the user I am logging has this Access Group and when I turn off "Use External Authentication" and revert the Service Package back to "Basic" authentication I can successfully invoke the service.
It's a tough one, anyone have any ideas? Is my approach correct? What am I missing?
Elad.
Helllo,
The description of the issue says that the service package access group doesn't have any valid service-http to serve the request.
However, in your custom code for the kerberos authentication, you need to specify the access group after successful authentication. I believe, it is getting the right access group.
