Unable to Locate Modal Dialog Window Settings In Pega 8.3
I have been working on customizing certain modals inside an SFA application and I ran into a issue where one of the Modals was not resizing properly to the Table its displaying. I eventually figured out that the sizing of these windows was controlled by something called "Modal Dialog Window Settings" which should have been configurable when I Edit the Application skin. However, I have not been able to locate this setting or it is named something I am not familiar with.
Where are the Modal Dialog Window Settings so I can properly resize my Modals?
Thanks in Advance
Hi Jay,
Please go to application skin - Click on Modal dialogs - Then created a new format or Inherit existing and override it
You can see Modal box tab - Dimensions - Choose the modal size from there accordingly.
After saving the format. You can use it for Modal format in action tab.
