class not match in modal dialog action set
Hi ,
section is in DATA -PORTAL Class ..
i need to display the section which is in other work class through the modal dialog action set .
when i click the button it should launch the section .
But I'm getting error like Failed to find a 'RULE-OBJ-FLOW' with the name 'XX' that applies to '@baseclass
- 1 related to applies-to class '@baseclass', but were defined on subclasses: 'xx-xxx-xxxx-work-xx'.
- Unable to perform {1} : assignment does not exist.
***Edited by Moderator Marissa to update Capability tags****
