Virtusa
Virtusa
Virtusa
Posted: Jan 1, 2020
Last activity: Jan 2, 2020
Last activity: 2 Jan 2020 12:01 EST
Generate BLOB Manually
Hi ,
What is the function / API to be used to generate blob manually , this is just for exploring and have no specific requirement to generate it manually .
Thanks.
Either the BLOB column (pzpvstream) has been added to the DB table to which a class is mapped or it has not been added.
If a pzpvstream column does exist, it is used to store the value for any and all "unexposed" Properties, an "exposed" Property being one that is mapped to a database table column.
Tables created in the the CustomerData schema do not have columns that start with px, py, or pz.
If you somehow create a Property in a class mapped to a CustomerData schema table without exposing a column for that Property, you will incur an error when attempting to save to that table.
To see how to define a pzpvstream column use a DB tool such as pgAdmin4. Navigate to a table, right click, select Scripts -> CREATE Script.
EX: pzpvstream bytea,
