Customize the column command menu in drill down report
I have requirement to customize the Pega OOTB for column command menu in drill down report. The command menu is implemented using 'pzGridMenuNavRule' navigation rule (Please refer to attachment). This rule is final and internal. This would be very grateful if you could suggest any feasible way to achieve this.
