tata
MX
Last activity: 19 Dec 2019 12:36 EST
BlueZone V 7.1 and OpenSpan Studio 19.1.1
Bluezone V.7.1 only has a 64bits of dll WHLAPI "WHLAPI64" I configured as in the videos of advanced the course, but it throws the error in the image, is any special configuration to use the 64 bits version or is not compatible? if it requires some especial configuration could you give it please?
I have attached the text adapter properties, the windows adapter properties and the error images
Thanks in advance
When using a text adapter, the adapter connects to a running session; basically the opposite of every other adapter that starts an application and then connects to it. This is why you use two adapters. The Windows adapter will launch the session and bring it up and make sure that it is loaded. After that, you'll call "Start" on your text adapter to connect to that session. Make sure you disable StartOnProjectStart for the text adapter.
