HCL Technologies Ltd
Last activity: 21 Nov 2019 8:36 EST
Scrollbar not appearing in AutoComplete Control 7.2.2 Version
The similar issue was fixed in 7.2 with a local change. Please have a look on it.
https://community.pega.com/support/support-articles/scroll-bar-not-appearing-auto-complete-control
Hope this helps!
Is the autocomplete configured seperately in a layout or inside a table? How many results does the autocomplete display? What is the source of the autocomplete?
Provide screenshots for detailed information.
Geeda.
Hi Geeda,
Yes I am using Inside a table, It's displaying 15 results out of 18, source of the autocomplete is DataPage.
Ravi
Hi Ravi,
Could you please ensure does any limits were set to the Autocomplete property to display in the "Max results displayed" field in the "General" tab of Autocomplete cell properties.
Hope this helps!
Hi Geeda,
Resolution
Perform the following local-change: <style>.autocompleteAG.pz-po-c{overflow-y: auto !important}.yui-skin-sam gPXFixed floated #gridLayoutWrapper {height:auto !importatnt;overflow-y:hidden !important;} </style>
Where can i apply this? in section/skin/layout?
Ravi
Hi Geeda,
Resolution
Ravi
Add the provided code snippet in the UserWorkForm and check if it resolved the issue.
Thank you Very much Geeda.
It's working as expected.
Ravi
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/acf9b3f6-41e7-4ef2-9e55-8da39714b54f.jpg?itok=JYQYUbWS)
Hi Ravi,
Thanks for confirming the resolution. We have marked Geeda's reply as the Correct Answer.
