Maantic Inc
Last activity: 8 Apr 2020 12:54 EDT
is it possible to create declare trigger on index table?
System has work and index table.
Index table loads data based on declare index, is it possible to create declare trigger on index table and load data to another table.
Tried creating declare trigger with Saved option, system is not triggering.
Infomatics Corp
Did you try creating the declare trigger in the Index class where the Instance is written to the table?
Maantic Inc
Yes, I did, declare trigger is not working on index tables.
Infomatics Corp
In which class the Decalre Trigger is Created?
BPM Company
Unfortunately, as you mentioned - declare triggers are not working in Index- classes.
Maantic Inc
is it product behavior?
reason, we tried on index table is technically it does db save and update.
BPM Company
AFAIK, yes - it's a product behaviour
Infosys
Hi Vaspoz,
I have a similar issue, declare trigger is not working on index class. Do you any alternative solution to store data in Index table?
Wells Fargo
Anybody has solution on this? Declare trigger created on index- class is not at all firing. Is this expected?
