how to create declare index
Hi
I've heard that one solution to create declare index is to optimize property, then index class will be created automatically...
However, nothing happens after I try to optimize properties...
Is it necessary to create index-class manually?
Could you tell me how to create declare index?
I really need your help.
Best regards,
When you optimize the property inside the Pagelist, the Declare index would be automatically created. Could you please check the records of Declare Index and Class if a new one got created.
Are you trying to optimise the property which is inside the pagelist?
