Unable to extract from PDF
I have installed robotics studio Proprietary information hidden
But I'm unable to extract anything from the PDF.
Am I doing something wrong?
That will simply return a blob of text for the entire document. 19.1.14 introduced an all new PDF Connector that should make reading what you need from PDFs much easier. If you are still having issues, please attach an example PDF and we can produce a simple solution to extract it. If you cannot attach it here, then you might open a support request to get them to take a look at the PDF to see if it has some issue with it.
