JP Morgan Chase
Last activity: 16 Oct 2019 8:46 EDT
Work objects ending in flow error due to max flow count reached
In our application there are some work objects which has to go to recurring cycle and hence same set of flows are called every month and workobject is open since 2016.
Now in 2019 the work objects started going to flow error and the error says -
Could not embedded flow page, the limit of flows of the same type may have been reached. The limit pxmaxflowaddcount is 50."
My question is - when i go to clipboard of the workobject i don't see pxflow page group more than 10. What am i missing? Which property in clipboard should i go and check to see the flows has reached more than 50?
What do you see for the flow names on the work object? When it goes through the same flow, you will see "flowname_count".
