Bank of America
Last activity: 30 May 2020 8:49 EDT
Screen flow step query
Inside a screen flow, how do I go back from last assignment to first assignment on click of button
***Edited by Moderator Marissa to move from Pega Academy to Pega Support Community; update platform capability tags***
You can get the task name and flow name from the flow XML or look at the data on the pyWorkPage.pxFlow page. If you run your flow and use the OOTB breadcrumb navigation to go back to the first assignment, you can trace it and see the parameter values being passed. The OOTB navigation uses the GoToPreviousTask and jumpToTask activities.
Optum
What business requirement would need such a setup, where first assignment gets launched on finishing the last assignment?
Bank of America
Hi Srinivas,
In a screen flow, need to go back to the first on click of a button in the third screen.
Kindly assist to achieve the above requirement
You can try using the jumpToTask activity.
Bank of America
what should i give in the task name and flow name
If you have the breadcrumb navigation shown, users can also click on the breadcrumb to go back to the first task.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689954000/5e1df259-88ec-40db-aa4a-a5b27280a5f7.jpg?itok=ChGegHBG)
Using work-.GoToPreviousTask activity can be another choice.
Bank of America
Thank you all , will try all the possible.
CBA
Hi Lavanya, can you share the document or screenshot for the configuration you used-- will be helpful.
TIA.
CBA
Can you please reply
