Will < -Dindex.directory="server/searchindexdir/somedexdir > bypass default search node?
In our multi node environment we are considering not having a search node (<node-type> =< search>). if we don't have a specific dedicated search node(s) (the standard Pega behaviour is that the first node that starts become the search node), and to avoided the first node that start becoming the search index node, is it ok to configure <-Dindex.directory="server/searchindexdir/nsomedexdir> to point to a specific node in the cluster?
So in layman terms, if I don't specify a search node, but specify which node-type the search index will be on, will that cause any issues that you know of?
