Sensiple Software Solutions Pvt Ltd
Last activity: 21 Aug 2019 5:26 EDT
Use of master-detail option for the row editing field under the operations tab
In the repeating dynamic layout properties, use of master-detail option for the row editing field under the operations tab
Wipro
Can you please elaborate what is the issue/requirement?
I just want to know what is the use of that option.
Wipro
Select the master-detail to enable the user to edit the details of a master object. The user can navigate between master objects and make changes to details without leaving the page.
The most common example of such a row editing mode is the modal dialog - here, the editable fields for a flow action appear in a modal window on top of the current master window.
The other options can be checked in the product help.
FR
Is it the same discussion again: https://collaborate.pega.com/question/use-defining-flow-action-operations-tab-layout-properties
Marc Cheong
No. In this post my question is use of master-detail option for the row editing field.
Hello Leelavathi,
Are you referring to Table or Repeat Dynamic Layout(RDL). However, RDL does not have master details option under the Operations tab.
Praveen
Yes praveen, I am referring to an table.
Hello ,
Please refer below article for detailed information regarding master-detail option for grids:
Praveen
