Infosys Limited
Last activity: 12 Dec 2019 22:54 EST
How to Handle Windows Security Pop-up
Hi Team,
I am trying to automate SAP Transaction using Pega Robotics. The SAP System under this Implementation uses SSO certificate Authentication. Hence, when we log in to the application for the first time in a day, we get the Windows Security pop-up, asking for credential.
I have tried using HookChildProcess to handle this, but I am unable to interrogate this pop-up. Kindly let me know if there is any method to handle this.
Thanks in Advance.
Updated: 2 Jul 2020 6:34 EDT
I had a session with Sanjay and we created attached script that helped on Windows 10.
Have you tried using OCR method? If not you can follow the below link to see more about how to use OCR feature
https://community.pega.com/knowledgebase/documents/creating-automations-using-screen-ocr-feature
You must interrogate the outermost window of the application. Once you have that, then you can call the various OCR methods on that object (along with SendKeys) to accomplish your tasks.
Srini
Here you need to write a UI Automation to automate the windows Security popup. Below sample code will help you to automate the security popup in windows 10.
sample link: https://repne.wordpress.com/2013/02/25/using-uispy-to-handle-the-windows-security-dialog-in-windows-7/
Sample code:
Sample code:
Please let me know if you have any queries.
Infosys
Hi Pavel, can you please attach the automation screenshot of this.
Infosys
Thank you for sharing script and will help others a lot.
