Refresh harness from activity
Is there a way to do Refresh current harness from activity?
This is 7.2.2.
This is 7.2.2.
function refreshCurrentHarness() {
var param = {event: [], dataTransform:[], activity:[], submitOnRefresh:true};
pega.api.ui.actions.refreshHarness(param);
We used this Javascript function and Pega API to solve our problem.
On click of a button, call Run Script (refreshCurrentHarness).
We can define the JS function in a non-auto generated section, which we included in UI where we are clicking the button.
I would check out these related threads.
https://collaborate.pega.com/question/how-refresh-harness-activity
https://community1.pega.com/community/pega-product-support/question/refresh-harness-within-activity
There is an OOTB activity @baseclass.ReloadHarness that you can use.
This is the same activity that PRPC trigger based on UI event when you choose UI event action as 'Refresh current Harness'
