How to refresh parent harness from Pop up harness closure.
How to achieve, refreshing of Parent Harness on closure of Pop up Harness.
Shruti
Shruti
Hello!
Shruti let us know over a private message that her team decided to go with a different approach.
Instead of navigator, we used local action to create case and refresh the Harness.
Hi Shruti,
You can add the "Refresh current harness" action in the parent location where you are opening the Modal window. For example, On click of my button i am calling the Local action to launch my modal window and then Refresh-Current-Harness as shown in attachment.
This way it will refresh your current harness after you close the Model popup window.
Regards
Mahesh
Hi Mahesh,
Refresh-Current Harness will work for modal window alone.
But this senario is, on close of pop-up(seperate window) we need to refresh parent harness.
Just a thought.
On popup harness, you can have a button, where you can add an event click.
On this event have the following actions.
1) Close the current popup harness.
2) Since now the current harness will be a parent one, you can do a refresh harness as suggested earlier.
Rachit
It will consider Pop-up as current harness as control is still in pop-up. Tried this suggestion!
Hello!
