BIX - Extracting pyHistoryType is not working
Hi, i have to extract with BIX the records from History tables where pyHistoryType is not null.
By the way, in some extracts I am able to use this property in the filter criteria, in some others i am not.
Any clue on what could be the problem? Any misconfiguration?
Vicio
Could you please let us know whether you have selected the property .pyHistoryType in the extract rule where you are facing this issue.
If not, would request to select the same property in the Definition tab and verify the result.
