Vodafone
Last activity: 7 Dec 2019 11:25 EST
QueryVBDOperation - java.lang.ArrayIndexOutOfBoundsException
Team,
we are observing so many entries like below in Pegarules.log file in production environment.
2019-06-20 07:56:55,174 [n-operation.thread-0] [ STANDARD] [ ] [ ] (ce.operation.QueryVBDOperation) FATAL - [ Proprietary information hidden]:5751 [vbd] [3.8] null
I am not getting any clue about this error. does it indicating any bad health?
we are using Pega 7.3.1.PFA, complete log file
FR
This is apparently coming from activity called "populatemeasurementmapper" which is then calling "retrievedata" finally generating the error on step5.
Can you check what this step5 is doing exactly, usually this error is due to a function trying to split a string for example which is too small or something like that.
Vodafone
Hi Marc,
This is getting invoked as part of retrieving campaign performance details from IH tables.On step5 of retrievedata, its trying to create the query and call VBD service.
there it was throwing the error.
Please find below code snippet where we could see multiple string manipulations and we could not find the culprit function for the error.
It would be great help if you could help here
Code snippet :
if (null == resultsPg) {
resultsPg = tools.createPage("Embed-PegaMKT-Measurement-Definition-Interaction", "QueryResultsPage");
// Now switching to com.pega.decision package structure...
//get result
try {
com.pega.decision.vbd.service.VBDService service = pega_decisionengine_vbd.pzGetVBDService(tools);
com.pega.decision.vbd.query.QueryResult result = service.query(query);
Hi Marc,
Code snippet :
//get result
try {
//print result
if (result != null && result.hasValues()) {
double[] resultArr = result.getValues();
for (int i=0; i<resultArr.length; i++) {
//Put the result into the measurement result map, keyed by name.
double[] theResult = new double[1];
theResult[0] = resultArr[i];
measurementResultsMap.put("{" + measurementNameList.get(i) + "}", theResult);
else if (result.entrySet() != null) {
//We had grouped results - walk the QueryResult object's entries
Iterator setIterator = result.entrySet().iterator();
//for reference - this is the total tally of the requested measurements across all binned results
double[] runningTally = new double[measurementNameList.size()];
int binIndex = 0;
ClipboardPage labelsPage = tools.findPage("D_MKTTimeIntervalLabels");
while (setIterator.hasNext()) {
try {
com.pega.decision.vbd.query.QueryResult.ResultEntry myResult = (com.pega.decision.vbd.query.QueryResult.ResultEntry)setIterator.next();
com.pega.decision.vbd.query.QueryResult myQueryResult = (com.pega.decision.vbd.query.QueryResult)myResult.getValue();
com.pega.decision.vbd.client.GroupedValue myGroupedValue = (com.pega.decision.vbd.client.GroupedValue)myResult.getKey();
//assuming a time binning as first grouping - grouped values will be in the format "default=x" where x is the number of bin intervals from start date
String groupedValueIndex = (String)myGroupedValue.get("default");
binIndex = Integer.parseInt(groupedValueIndex);
//keep track of the lowest bin interval - this will help us match up the proper label for displaying the results
binOffset = binIndex + 1;
String intervalLabel = "";
String binLabel = "";
ClipboardProperty labelsProp = null;
if (labelsPage != null) {
labelsProp = labelsPage.getProperty("TimeIntervalLabels");
if (null != labelsProp) {
intervalLabel = labelsProp.getStringValue(binOffset);
binLabel = intervalLabel;
intervalLabel = intervalLabel.replaceAll(" ", "_").replaceAll("-", "");
if (intervalLabel.length() <= 0) {
intervalLabel = "All";
//Year will be numeric - append a character to allow for use as PageGroup index
else if ("Year".equals(intervalParam)) {
intervalLabel = "Y" + intervalLabel;
//our results were only binned by time in this case - update runningTally and store the results indexed by the bin interval
if (myQueryResult.hasValues()) {
double[] myDouble = myQueryResult.getValues(myGroupedValue);
for (int i = 0; i < myDouble.length; i++) {
runningTally[i] = runningTally[i] + myDouble[i];
ClipboardPage r1 = resultsPg.getPage("ResultsGroup(" + intervalLabel + ")");
r1.putString("GlobalGroupingLabel", binLabel);
ClipboardPage r2 = r1.getPage("ResultsGroup(" + measurementNameList.get(i) + ")");
ClipboardProperty measure = r2.getProperty("Measure1");
ClipboardProperty ordering = r2.getProperty("SortIndex");
measure.setValue(myDouble[i]);
ordering.setValue(binOffset);
//store the bin results indexed by bin interval, for further calculations
} else if (myQueryResult.entrySet() != null) {
// We have time & local grouping
Iterator setIteratorInner = myQueryResult.entrySet().iterator();
double[] innerTally = new double[measurementNameList.size()];
while (setIteratorInner.hasNext()) {
try {
com.pega.decision.vbd.query.QueryResult.ResultEntry innerResult = (com.pega.decision.vbd.query.QueryResult.ResultEntry)setIteratorInner.next();
com.pega.decision.vbd.query.QueryResult innerQueryResult = (com.pega.decision.vbd.query.QueryResult)innerResult.getValue();
com.pega.decision.vbd.client.GroupedValue innerGroupedValue = (com.pega.decision.vbd.client.GroupedValue)innerResult.getKey();
//assuming a string-based binning as our inner/local binning - inner grouped results will be in format "levelParam=xyz"
String groupedValueIndexInner = (String)innerGroupedValue.get(levelParam);
//remove <> symbols; translate spaces to _ character for clarity
groupedValueIndexInner = groupedValueIndexInner.replaceAll("<", "").replaceAll(">", "").replaceAll(" ", "_").replaceAll("-", "");
if (innerQueryResult.hasValues()) {
double[] innerDouble = innerQueryResult.getValues(innerGroupedValue);
ClipboardPage r1 = resultsPg.getPage("ResultsGroup(" + intervalLabel +")");
ClipboardPage r2 = r1.getPage("ResultsGroup(" + groupedValueIndexInner + ")");
r2.putString("LocalGroupingLabel", (String)innerGroupedValue.get(levelParam));
r2.putString("GlobalGroupingLabel", binLabel);
for (int i = 0; i < innerDouble.length; i++) {
innerTally[i] = innerTally[i] + innerDouble[i];
ClipboardPage r3 = r2.getPage("ResultsGroup(" + measurementNameList.get(i) + ")");
ClipboardProperty innerMeasure = r3.getProperty("Measure1");
ClipboardProperty ordering = r3.getProperty("SortIndex");
innerMeasure.setValue(innerDouble[i]);
catch (Throwable t) {
oLog.error("Not able to get the timeframe and locally grouped value from VBD");
oLog.error("Error is " + t.toString());
} else {
oLog.info("myQueryResult has NO values" );
} catch (Throwable t){
oLog.error("Not able to get the timeframe grouped value from VBD");
} //while
catch (Exception e) { oLog.error("Unable to query VBD: " + e.getMessage()); }
//This activity will recursively call itself to arrive at the calculated set of answers for the requested KPI (Operand)
paramPage.putObject("Expression", paramName);
StringMap keys = new HashStringMap();
keys.putString("pyActivityName", "CalculateKPIExpression");
tools.doActivity(keys, resultsPg, paramPage);
Vodafone
Also, we are observing multiple entries like below in production
Unable to query VBD: nul
during multichannel campaign run today .
but if i change actual start date, i will be losing all IH data? i dont think this is correct solution in our case.
Please suggest here
MADDULURI VENKATA SAI KALYAN
Vodafone
any suggestions would be much appreciated in this case
