Unable to start the process calc.exe. Start process injected failed.
I am getting below error when interrogating using windows adapters.
Microsoft Visual Studio
Unable to start process calc.exe. Start process injected C:\Windows\System32\calc.exe failed
OpenSpan.Adapters.Windows
at OpenSpan.Adapters.Windows.WindowsProcess.Start(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout)
at OpenSpan.Adapters.Windows.WindowsAdapterBase.StartProcess(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout, Boolean hookChildProcesses, IWindowsProcess& process)
at OpenSpan.Adapters.Windows.WindowsAdapterBase.StartProcess(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout, IWindowsProcess& process)
at OpenSpan.Adapters.Windows.WindowsAdapter.StartAdapter()
at OpenSpan.Adapters.Adapter.HandlePerformStart(Object sender, CancelEventArgs e)
at OpenSpan.Design.DesignComponentCommon.OnPerformStart()
at OpenSpan.Design.DesignComponentCommon.Start()
at OpenSpan.Design.DesignComponent.Start()
at OpenSpan.Adapters.Design.InterrogationService.StartInterrogation()
OK
I am using Windows 10 , VS 2015 and Pega Robotics Studio 8.0.2015.0
OK
Pega Robotics doesn't support Windows 10 Calculator below is the related document.
https://collaborate.pega.com/question/unable-interrogate-calculator-application-pega-robotics-80-windows-10
