Validate Error Visible
Hello
To check the input I use Edit Validate rule.
When entering erroneous data error does not appear.
I set up an Action Set, in which, by changing the value (Event - Change), I use Action "Post value", an error appears, but if I click on the field and remove the cursor from it (without changing the field value, the error disappears from the user's form (in the clipboard displayed)
How to make it so that the error is always displayed?
Can you confirm if the "Always show error" checkbox for the harness has been enabled? Additionally do let us know the version of Pega you are using.
You could check the below article as well:
https://community.pega.com/support/support-articles/errors-flash-and-disappear-screen
