tcs
Last activity: 22 Oct 2019 2:02 EDT
How to use Keystore, truststore without mention in connect-rest rule? how to create truststore in pega?
You can specify both keystore/truststore at the application server level. What is your app server? The actual details are app server specific.
tcs
LTIMindtree
tcs
Barclays
We are facing the same issue when performing REST integration, is there is any solution or a work around fix for it ?
com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: com.pega.pegarules.pub.services.ConnectorException: SSL configuration: unable to instantiate JSSE socket factory
For the socket factory exception, could you please try to look at the below articles for the resolution:
https://community.pega.com/support/support-articles/issue-while-running-webservice-protected-webseal
https://community.pega.com/support/support-articles/soap-service-picks-incorrect-transport-layer-security-version
https://community.pega.com/support/support-articles/soap-error-after-upgrade-0
What is the version of the Pega platform?
Also try by enabling the Dynamic System Setting "https/allowAllHostnames" in "Pega-IntegrationEngine" ruleset to "true".
