Creating and establising a Pega Connect-REST to AWS OAUTH 2.0
hi,
trying to create a Connect-REST from Pega to a AWS system which hosts a service to provide a response when Pega sends JSON request.
the authentication the AWS service uses is an OAUTH 2.0 and hence they have provided a secret and access key. when we create an authentication profile with Type as Amazon Web Services (AWS) on Pega and when called in the Connect-REST, "Use authentication profile" on the "Authentication section".
on saving the connect-REST rule, an Pega error stating "Auth Profile— Amazon Web Services (AWS) Authentication Profiles do not work with this rule type.".
See attachment.
It seems pega does not allow AWS type authentication profile to be set on Connect-REST.
Is there any way we can set this up this connection? looking for steps to follow to establish a connection to AWS, send a request and get a response.
thanks and regards,
Rajesh
***Edited by Moderator Marije to add INC-B8845 tags***
