Secure PDF
Hi
Does the PDF connector support secure PDF?
When I connect to the PDF, the PDF viewer is blank. However, it will work with an unsecure PDF.
Thanks in advance.
Hi
Thanks in advance.
Hi VikkiL94,
It is not supported currently.
However, you can write a java code to copy secure pdf pages to another pdf and use this new pdf as file for PDFConnector.
