Accenture
Last activity: 28 May 2019 23:57 EDT
CallScript component help
Why exactly we needed this CallScript component in Pega Robotics?
We can use the script component to dynamically send the values to variables used inside the script/input parameters.
How does script and callscript differ?
Can we write C# syntax code in Callscript editor?if yes, how can we validate the script?if No - the string with dynamic parameters(tokens) can even be acheived with stringutils?
I am not able to see the Callscript Popup using show method. I am getting error "Invalid URI: The format of the URI could not be determined."
How does this Call script - Device work please share an example.
Please help.
Thank you!
