Pls suggest best approach to generate and download PDF
Can anyone suggest best approach to generate and download PDF ?. Pls share the sample code.
cheers-
Pavan
cheers-
Pavan
Please check below link.
https://collaborate.pega.com/question/pdf-generation-and-download-pdf-browser
https://collaborate.pega.com/question/generating-and-viewing-pdf
https://collaborate.pega.com/question/generate-pdf-file-using-smart-shape
HI,
There is an OOTB activity called 'HTMLtoPDF' that can be used to generate a PDF. You will have to pass a section to this activity to convert into a pdf. Alternatively while creating a flow there is a smart shape "Create PDF" that can generate a pdf.
