Connect-FTP with pegacloudfilestorage
I am trying to use the Connect-FTP method to send a file to an SFTP Server that I have created. I am storing the case attachment files on the pegacloudfilestorage repository. When I execute the Connect-FTP method on the activity, I am always getting the error:
Error working with local path: 'attachments/prueba_AJ-68.txt', File does not exist or cannot be read: attachments/prueba_AJ-68.txt
Find attached screenshot of the activity parameters. Also, I traced downloading of the file (from the History & Attachments screen on the case), where I can see the file's path and repository details.
Am I using a wrong syntax? I also tried specifying the full path as "file://pegacloudfilestorage:/attachments/prueba_AJ-68.txt", but the result was the same.
Thank you
Can you clarify the sftp server: is it outside pegacloud environment (i.e, really your own) or is it the one coming with pegacloud?
