Nordea
SE
Last activity: 22 Jul 2019 4:58 EDT
Migrating Upgraded Rule Schema
I am migrating rule schema to higher environments & this rule schema is already upgraded to pega 8.1.1 in lower environments so I will only need to upgrade data schema separately later. Could we check if the below parameter in Migration file is correct as I am not sure if they are valid of migrating upgraded rule schema:--
pega.move.admin.table=false
pega.clone.generate.xml=true
pega.clone.create.ddl=true
pega.clone.apply.ddl=true
pega.bulkmover.unload.db=true
pega.bulkmover.load.db=true
pega.rules.objects.generate=true
pega.rules.objects.apply=true
