Issue in Publishing the package to Server
I am getting below message when I am trying to deploy a project
1) Exception Information
Exception Type: System.ApplicationException
Message: ""
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: Void PublishPackageToManagementConsole(System.String, Byte[], System.Collections.Generic.List`1[OpenSpan.Studio.Solution.DesignProject+DeploymentProfile], System.String)
HelpLink: NULL
Source: "OpenSpan.Studio"
HResult: -2146232832
StackTrace Information
at OpenSpan.Studio.Solution.DesignProject.PublishPackageToManagementConsole(String packageName, Byte[] packageData, List`1 profiles, String packageComment)
at OpenSpan.Studio.Solution.DesignProject.DeployProject(Boolean deployAll)
I don't think that contains enough information to speculate. I would suggest that you open a support request as it will likely take some examination of your source code and/or logs to determine the specific issue. If you do open a support request, please add the number here so the resolution can be added when it is resolved.
