Standard Charted Bank
Last activity: 14 May 2019 16:15 EDT
Predictive Model: Export / Import feature purpose
As part of my project , I am analysing Pega's predictive model capabilities. As part of it, I came across the following:
Export / Import feature (screenshot attached)
As per the Pega 7.3.1 help file, this feature will be used to move the Predictive model between environments.But, we can do the same by using Rule- Admin- Product rule.
I like to understand the benefits of Export/Import feature over R-A-P approach.
Saravanan
Exported predictive model zip has totally different format versus R-A-P, it is only used for Pega decisioning model import/export, predictive models are specific Pega Decision Hub and are NOT rules. If you expand the exported zip files you will see the difference.
