Pega Unit Testing for Sub Flows
I want to create a test case for subflow. But I can't use record test case option from the subflow actions tab as it is not really taking me to actual subflow and needs to recorded from parent flow(pyStartCase) only. I red in pdn that test case for sub flow would be against parent flow only, so I tried to record the test case from parent flow itself but whenever there is an assignement created and routed to some WB/WL, the record test case option is getting disappeared. Can someone please suggest the way to create tests case for sub flows ?
Thanks!
Regards
Rajasri
