Nordea
SE
Last activity: 24 Apr 2019 15:19 EDT
Data Import using command line
I was trying to import an admin operator from another environment using command line as I have forgotten the credentials of the same. After executing "prpcUtils.sh import" command, log shows that it has skipped overriding the record but if you see the attached property file, i have selected override option. it seems this option is valid for rule instance only. Could you please suggest? Attaching the log file as well.
