Deploy a project using command line
Hi
I am trying to automate the process of deployment, just as we do in case of bamboo. The problem statement is
We need that a build is created automatically as soon as we merge the code to the main branch. For that to happen, we need that we have a way to deploy the project via command line. Can anyone please suggest if we can do that?
***Updated by moderator: Lochan to update platform capability***
Thank you for posting on PSC. I found this article in my search: How to import or export an archive from the command line
Have you referred this already?
Also, I removed the Robotic Automation tag on your post since i believe that you are not using Pega Robotics. Please correct me if I am wrong to assume that.
