Elliott Moss Consulting
ID
Posted: Apr 5, 2019
Last activity: Jun 18, 2019
Last activity: 18 Jun 2019 14:52 EDT
Hi, I have a report in a hierarchical table (PFA), and I want to export it as PDF. As of now, the exported pdf is unreadable. How to accomplish this requirement?
Best regards
I'm not sure how much control over PDF format is available through the platform PDF export facility. You may be able to have more control in BIX.
You might consider flattening the report using a declarative index join. It would probably convert to a more straightforward PDF output.
