CGI
CGI
CGI
Posted: Apr 3, 2019
Last activity: Jul 1, 2019
Last activity: 1 Jul 2019 2:47 EDT
Component stack mismatch
we are getting below error randomly on different screens in pega 8.1.1 if we SSO link. If user prweb Link without SSO everything work fine.
Section 'pyCaseMain' execution error on page 'pyWorkPage' of class '$class'.
Show More
java.lang.RuntimeException: Component stack mismatch {"pyCell":{"pyType":"layout","RWActive":"false","partialClass":"flex flex-row","spanClass":"iconRequired standard_iconRequired","cstmreqfor":"pyRequired","labelJSP":"false","pyLabelValue":"","pyVisibility":"true"},"pxWhenIdentifiers":{"pyVisibilityWhenId":"c8f9e7571077561043fb14c11e9ea3caf47710a_75"},"pyName":"DynamicLayoutCell","pyTemplates":[{"whenId":"c8f9e7571077561043fb14c11e9ea3caf47710a_75","pyName":"pxVisible","pyTemplates":[{"NTId":"8049386755222","NTRef":"c8f9e7571077561043fb14c11e9ea3caf47710a_65","pyName":"pxNonTemplate"}]}]}!!!!===={"paramName":"EXPANDEDSubSectionpyCaseMainBBB","sectionIndex":"3","isSectionIncl":"true","lMode":"Inline-block","pxWhenIdentifiers":{"pyVisibilityWhenId":"7000fb839b6ea83fe3ecf184bd58d33e8cb70da0_6"},"pyName":"pxLayoutContainer","pyTemplates":[{"pxReferencedId":"7000fb839b6ea83fe3ecf184bd58d33e8cb70da0_5","pyName":"pxSection"}]}
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.json.UIComponentRuntimeImpl.finishProcess(UIComponentRuntimeImpl.java:175) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.json.AbstractUIComponent.endComponent(AbstractUIComponent.java:89) ~[prprivate.jar:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.pzLayoutContainer_3(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:452) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.pzLayout_3(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:476) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.pzSectionBody_1(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:268) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.performStream_1(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:682) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.execute(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:144) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:4095) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuleRuntime.getSectionStream(AutoStreamRuleRuntime.java:151) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.executeSection(ContextProcessor.java:1086) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.processSection(ContextProcessor.java:1073) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.processSection(ContextProcessor.java:1323) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.RuntimeContextTree.loadSection(RuntimeContextTree.java:487) ~[prprivate.jar:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.buildSection_2(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:3029) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.includeSectionBody_2(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:3035) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.generateWorkAreaLayouts_1(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:3152) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.processWorkAreaLayouts_1(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:3323) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.createFormElement_1(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:3368) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.createPegaHarnessDIV_1(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:3976) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.includePegaHarnessContent_1(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:4006) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.buildHarnessMarkup_1(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:4149) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.performStream_16(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:4228) ~[?:?]
at com.pegarules.generated.html_harness.ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.execute(ra_stream_perform_7900b2240f9aee04e1e9987257c610f2.java:153) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3917) ~[prprivate.jar:?]
at com.pegarules.generated.activity.ra_action_reloadharness_3d03f37db7a6ba0b5d76ca95c41b4cb2.step10_circum0(ra_action_reloadharness_3d03f37db7a6ba0b5d76ca95c41b4cb2.java:1082) ~[?:?]
at com.pegarules.generated.activity.ra_action_reloadharness_3d03f37db7a6ba0b5d76ca95c41b4cb2.perform(ra_action_reloadharness_3d03f37db7a6ba0b5d76ca95c41b4cb2.java:224) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3556) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:489) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3718) ~[prprivate.jar:?]
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:435) ~[prenginext.jar:?]
at sun.reflect.GeneratedMethodAccessor66.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_162]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_162]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1377) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1109) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:963) ~[prprivate.jar:?]
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:361) ~[prenginext.jar:?]
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:882) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:331) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:274) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:251) ~[prprivate.jar:?]
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:275) ~[prpublic.jar:?]
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:220) ~[prpublic.jar:?]
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:712) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:398) ~[prwebj2ee.jar:?]
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source) ~[?:?]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370) ~[prbootstrap-8.1.1-247.jar:8.1.1-247]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411) ~[prbootstrap-8.1.1-247.jar:8.1.1-247]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) ~[prbootstrap-api-8.1.1-247.jar:8.1.1-247]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) ~[prbootstrap-api-8.1.1-247.jar:8.1.1-247]
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:129) ~[prbootstrap-api-8.1.1-247.jar:8.1.1-247]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:661) ~[servlet-api.jar:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) ~[servlet-api.jar:?]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) ~[catalina.jar:8.5.27]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) ~[catalina.jar:8.5.27]
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) ~[tomcat-websocket.jar:8.5.27]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) ~[catalina.jar:8.5.27]
at waffle.servlet.NegotiateSecurityFilter.doFilterPrincipal(NegotiateSecurityFilter.java:249) ~[waffle-jna-1.7.4.jar:1.7.4]
at waffle.servlet.NegotiateSecurityFilter.doFilter(NegotiateSecurityFilter.java:109) ~[waffle-jna-1.7.4.jar:1.7.4]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199) ~[catalina.jar:8.5.27]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) ~[catalina.jar:8.5.27]
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:504) ~[catalina.jar:8.5.27]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) ~[catalina.jar:8.5.27]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81) ~[catalina.jar:8.5.27]
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650) ~[catalina.jar:8.5.27]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) ~[catalina.jar:8.5.27]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342) ~[catalina.jar:8.5.27]
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803) ~[tomcat-coyote.jar:8.5.27]
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) ~[tomcat-coyote.jar:8.5.27]
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:790) ~[tomcat-coyote.jar:8.5.27]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459) ~[tomcat-coyote.jar:8.5.27]
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) ~[tomcat-coyote.jar:8.5.27]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_162]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_162]
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) ~[tomcat-util.jar:8.5.27]
Show Less
Looks like your pyWorkPage is having an unexpected class. Can you try to trace it to get more details?
