Tech Mahindra
Last activity: 26 Aug 2019 12:52 EDT
Error on page 'pyDisplayHarness' of class 'Data-Portal'. : Component stack mismatch
We are using pega 7.3.1 .We are calling a harness on change of dropdown from user portal and calling report definition inside of the section inlcuded in harness. In run time getting the below error
ErrorMessage:Section 'DisplayMyProcessActionResults' execution error on page 'pyDisplayHarness' of class 'Data-Portal'. : Component stack mismatch {"NTId":"1525939333446000","NTRef":"899294d96ffa65808f9eb3c0e2035c8d_148","pyName":"pxNonTemplate"}!!!!===={"liveUI":" data-ui-meta=\"{'type':'Container'}\" ","containerType":"CENTER","isClientWhen":false,"pyName":"pxHarnessContainer","pyTemplates":[{"pxReferencedId":"e9fea501cc2ba45aa6b9a372257ca25f_3","pyName":"pxSection"}]}
Ford Motor Company
Pega Supplied a HFIX to resolve the issue for PRPC 7.3.1,
| SR-C83095 |
| PARENT HOTFIX: HFIX-47303 DEPENDENT HOTFIX(ES):[HFIX-44651, HFIX-46877] |
Hi Naveen,
I hope that you have recently upgraded to 7.3 from previous version.
Pega 731 highlights bad design and implementation which were working in the pega 722. Some examples:
1) Data pages are validated now
2) Radiobattons doesn't work on pxPages anymore
3) Textarea controll renders incorrectly in the editable mode due to the wrongly generated html class
Hi Naveen,
Please check once your section that in Pages and Classes tab proper refrencing is given and even in the RD.
Thank you
-Abhishek
HealthFirst
Suddenly its working fine as per the expectations. Not sure may be cache memory issue.
Karim
Ford Motor Company
Iam getting this error for just one user, any thoughts around it?
Here is the stack:
Here is the stack:
Swati Sinha
Tata Consultancy Services
is this issue with previlige?
Ford Motor Company
I found that, the Data Page D_pzPreferenceStore not loaded properly for this user.
Did that resolve your issue? If not, please create a new post for your query.
Thanks!
Bank Of America
i am facing the same issue in 7.3.1 ,is there any root cause identified for this.in my scenario i am usinga list inside a list to show the contents,please advice.
Prateek Patnaik
Bayview Asset Management, LLC
any solution for this issue??
This post is inactive. Please write a new post so that your question gets visibility.
Any questions, let me know!
Ford Motor Company
| SR-C83095 |
The Hotfix referenced here HFix-47303, and the additional fixes for the specified SR, are actually for the 7.4 release.
It appears to address a form of the component stack mismatch error relating to switching access groups.
