Parallel Integrations
Hello.
I am currently facing the following problem: there is a PageList (called Products()) in my case and I need to use JMS-Connection to a remote system for every item in this PageList so that each item was a context for the request.
The problem is that there is a significant delay between making a request and getting a response from the system, that mostly involves transfering a message instead of an actual processing.
For example, I use JMS-Connect for Product(1), then wait for a response, then use JMS-Conntect for Product(2), then wait for a response again and so on.
I need to be able to send requests via JMS-Connect for all items in PageList at once and then get the responses for each one of them. Being able to have a parallel JMS Integration with the same requestor while I am still waiting for a response for a previous integration would drastically decrease the processing time.
Is there any way to implement this?
I tried to create subcases for every different item in PageList to get different threads but integrations still seem to operate in succession rather than in a parallel way. I also tried to check the RunInParallel box near Connect-JMS function but it did not help. It seems like the checkbox is supposed to parallel it with the main process (and then unite it again with Connect-Wait) instead of paralleling it with other integrations.
Hello.
