Regarding Pega RPA
We have modified the openspan config file and replaced the files of office 2013 but we are still getting the following error. Can you kindly provide any solution?
Thank you for posting your question in PSC.
When installing the Runtime, you must specify the version of Office that is installed on the machine. This message appears when there is a mismatch between the version of Office actually installed on the machine and the version that was selected when Runtime was installed. There are two ways to fix this,
Hope this helps.
Debraj
